Total posts in this thread: 6
Previous Thread This topic has been viewed 5619 times and has 5 replies Next Thread
chrix
Germany
Mac OS X Version 6.6.5 (MacApp Store) doesn't start
Hello,
i just got the Mac OS X Version 6.6.5 from MacApp Store.
My System:
- Big Sur (11.4)
- MacBook Pro 15 Zoll 2016
- 2,7 GHz Quad Core i7
- 16 RAM
Cannt get Sweet Home to start. If i start the Programm it start shortly 1-4 Seconds and than it close it.
Thanks for support.
Best Chris
[Jun 18, 2021, 2:20:41 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Mac OS X Version 6.6.5 (MacApp Store) doesn't start
I guess you mean version 6.5.5...
If Sweet Home 3D is installed in its default location, please launch it from a Terminal window with the command
/Applications/Sweet\ Home\ 3D/Contents/MacOS/SweetHome3D
and copy/paste what appears in the Terminal window.
[Jun 18, 2021, 11:20:27 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
chrix
Germany
Correct, i wrote the wrong Version its 6.5.5
[Jun 18, 2021, 11:35:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
chrix
Germany
Here is the terminal response:
You have mail.
/Applications/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D ; exit;
XXXXXXXX ~ % /Applications/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D ; exit;
Exception in thread "main" java.lang.NullPointerException
at sun.lwawt.macosx.LWCToolkit.getScreenWidth(LWCToolkit.java:362)
at sun.awt.SunToolkit.getScreenSize(SunToolkit.java:645)
at com.eteks.sweethome3d.swing.SwingTools.showSplashScreenWindow(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.init(Unknown Source)
at com.eteks.sweethome3d.macappstore.SweetHome3DMacAppStore.init(Unknown Source)
at com.eteks.sweethome3d.macappstore.SweetHome3DMacAppStore.main(Unknown Source)
2021-06-19 00:43:23.148 SweetHome3D[37008:748711] SweetHome3D:Failed to launch JVM
Saving session...
...saving history...truncating history files...
...completed.
Deleting expired sessions...none found.
[Prozess beendet]
After this i installed the latest Java Version. There is no effect on this. But i found the problem.
I using external Monitors based on Display Link Software (https://www.displaylink.com/). If i switch of my monitor hub Sweet will start. Its the only software i know have troubles with DisplayLink.
If you fix this problem in the next Version, would be nice.
Best Chris
[Jun 19, 2021, 12:08:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ManuMan79
On Macbook M1 Monterey(bêta 12.0 (21A5506j) :
Do'nt start :
From Terminal
Last login: Wed Sep 22 15:46:38 on ttys000
You have mail.
Emmanuel@MBP13-M1 ~ % /Applications/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D ; exit;
CoreSVG has logged an error. Set environment variabe "CORESVG_VERBOSE" to learn more.
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by javax.media.j3d.JoglPipeline (file:/Applications/Sweet%20Home%203D.app/Contents/app/j3dcore.jar) to method sun.awt.AppContext.getAppContext()
WARNING: Please consider reporting this to the maintainers of javax.media.j3d.JoglPipeline
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x0000000112321b44, pid=60551, tid=9475
# JRE version: OpenJDK Runtime Environment Zulu15.29+15-CA (15.0.2+7) (build 15.0.2+7)
# Java VM: OpenJDK 64-Bit Server VM Zulu15.29+15-CA (15.0.2+7, mixed mode, tiered, compressed oops, g1 gc, bsd-aarch64)
# Problematic frame:
# J 1245 c2 jdk.internal.jimage.ImageStringsReader.charsFromByteBufferLength(Ljava/nio/ByteBuffer;)I java.base@15.0.2 (47 bytes) @ 0x0000000112321b44 [0x0000000112321ac0+0x0000000000000084]
# No core dump will be written. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /Users/Emmanuel/hs_err_pid60551.log
Compiled method (c1) 2256 218 3 java.nio.DirectByteBuffer::<init> (55 bytes)
total in heap [0x000000010add3a10,0x000000010add41a8] = 1944
relocation [0x000000010add3b68,0x000000010add3bd8] = 112
main code [0x000000010add3c00,0x000000010add3fc0] = 960
stub code [0x000000010add3fc0,0x000000010add4078] = 184
metadata [0x000000010add4078,0x000000010add40a0] = 40
scopes data [0x000000010add40a0,0x000000010add4120] = 128
scopes pcs [0x000000010add4120,0x000000010add4190] = 112
dependencies [0x000000010add4190,0x000000010add4198] = 8
nul chk table [0x000000010add4198,0x000000010add41a8] = 16
# If you would like to submit a bug report, please visit:
# http://www.azulsystems.com/support/
zsh: abort /Applications/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D
Saving session...
...copying shared history...
...completed.
Deleting expired sessions... 6 completed.
[Opération terminée]
[Sep 22, 2021, 5:39:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ManuMan, your issue might be different and is probably due to the Beta version of Monterey you use. Please report it to Apple too.
[Sep 23, 2021, 9:31:28 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
