Total posts in this thread: 6
Previous Thread This topic has been viewed 2072 times and has 5 replies Next Thread
Clamarc
Brazil
How to create textures correctly
I created some textures for my project, but when I put them on very long walls, the textures are subdivided, that is, the program compels the wall with another texture frame and the wall does not have a uniform texture. Is there a texture size rule that is uniform across all wall sizes?
Thanks
Clamarc
[Apr 17, 2021, 1:03:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
clausschmidt
Germany
Re: How to create textures correctly
I have the same issue. Would be great if someone can help us solving this.
Thanks in advance, Claus
[Apr 22, 2021, 11:03:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Do you wonder how to design seamless textures?
If not, please share an image, it will help to understand your issue.
[Apr 22, 2021, 3:16:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Clamarc
Brazil
Hi Puybaret
how do I post the image? ... I created a link to the image on the google drive, but when I place the link here and go to preview, it does not appear for you to open it!
thanks
Clamarc
[Apr 22, 2021, 6:26:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
You can post the link to the image or read this thread but I'm not sure you can include images from Google drive.
[Apr 22, 2021, 6:43:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Clamarc
Brazil
Hi Puybaret,
I found a solution for my textures. Before importing them into the program, I am leaving the edges of them with the same hue as the interior of the image, it turns out that as the edges are always darker, they end up standing out when used on very long walls, because the program places the textures side by side when the wall is long. I also try to make a Gaussian blur on the edges to soften their junction when the wall is long.
Thank you for your attention and congratulations on the excellent program.
Clamarc
[Apr 23, 2021, 8:10:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2022 eTeks - All rights reserved
