Posts: 24   Pages: 3   [ Previous Page | 1 2 3 ]
Previous Thread This topic has been viewed 31266 times and has 23 replies Next Thread
jpcr
Re: Terrain Generator plug-in
hello,
I have installed the plug-in but i dont see the same screen than the latest version.
also , would you consider having negative elevation to make holes?
I do not see the wireframe option, is it because i am using the French version?
thank you for all your work!!
JP
[May 22, 2021, 11:30:37 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Check what version is running in the Librairies in use dialog box shown when you click on the Libraries button in About dialog box. If it's not the good version, install the version 1.1 of the plug-in and don't forget to restart Sweet Home 3D.
Would you consider having negative elevation to make holes?
I don't think this will happen, but you can create a room at a lower level (including levels with a negative elevation), elevate all the points in the plug-in and finally dig a hole in this terrain.
See this video for more details.
The wireframe option is available only from version 1.1 of the plug-in and when there are some walls, rooms and furniture to display.
[May 22, 2021, 3:07:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
jpcr
thank you Emmanuel !
the video helped a lot.
JP
[May 23, 2021, 8:15:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
BLGPHIL
Thank you for this great plugin which allowed me to create the altimetry of a very steep terrain to successfully lay out the house.
A small improvement would be to offer a possibility to undo the last changes without having to reset all.
Thank you again and well done for this plugin.
[Sep 16, 2021, 8:00:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2022 eTeks - All rights reserved
