Previous Thread This topic has been viewed 3835 times and has 2 replies Next Thread
bettyblus
About wall
Hi
need to create a upper wall like if I have a door what I can do to make it?
[Jan 28, 2021, 8:38:26 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: About wall
You could place a service hatch or a door frame to make a hole in a wall.
See also this tip for not rectangular holes.
[Jan 28, 2021, 1:44:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
Re: About wall
I uploaded a 1/8" thin (3-sided) doorway frame that won't leave a white edge on the floor. I created it for a large wall opening between my kitchen and dining room using the Furniture Library Editor and SVG code. It can be resized. I also did the same thing to create the slightly arched opening between my living room and dining room. I choose 1/8" thin frame edge thickness to get a "frame-less" as possible for simple wall openings. [EDIT: I deleted my prior post and combined in with the following.] Use this instead. It's a SH3F furniture library with the correct "door" versions that cut a hole in a wall. I think the other files I posted were the original versions of the opening shapes as an OBJ export. I'll delete those from my Google Drive to avoid confusion. Download the whole file (not the individual contents) and import into SH3D. I'm new at creating custom models so sorry for the screw up. I need a better workflow process. ;)
https://drive.google.com/file/d/1Mpoci-7JktEU...lvv3yXZl/view?usp=sharing
[Jan 29, 2021, 1:11:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
