Total posts in this thread: 2
Previous Thread This topic has been viewed 2727 times and has 1 reply Next Thread
rndlmn4
United States
'Levels' Tab Arrangement Changed?
The tabs for Levels, which sit below the tool bar and above the horizontal scale, were in a single row for the longest time. Now all of a sudden they appear in two rows. The strange thing is, when you select a Level, the row it is in becomes to the bottom row. If you select another Level from that row, the tabs don't change. But, if you select a Level from the top row, all of that row becomes the bottom row, and the other row moves up. It's causing me to work with a moving target. I spend too much time looking for the correct tab before clicking. How can I put all of the tabs back into one row?
[Jan 25, 2021, 3:42:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Cika
Re: 'Levels' Tab Arrangement Changed?
I don't think you can, it's the same problem I have.
When you have as many levels as me about 60, the automatic repositioning is crazy, it would be better if they stood still in their position.
I hope someone can find a solution, because the program is fantastic
[Feb 26, 2021, 6:15:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
