Re: Just purchased v6.4.7 from Mac App Store and Big Sur 11.1 - Crashes won't open
Could you try to run it from a Terminal window? Open Terminal application, drag and drop Sweet Home 3D icon on Terminal window, add /Contents/MacOS/SweetHome3D after Sweet\ Home\ 3D.app to obtain something like:
Then, press <enter> and copy paste here the text that will be displayed. This could help fix your issue.
Running to this exact same issue. When I followed your instructions above to run it through terminal I was successful in getting the program to launch. Any thoughts?
Could you check if you have this issue with the free version 6.4.2 and in the beta version 6.5?
[Edit 1 times,
last edit by Puybaret at Jan 29, 2021, 2:37:30 PM]
Joan20, your last message made me think you was a Ubuntu user. Did you change your computer? Does it run from a Terminal window?
