Total posts in this thread: 2
Previous Thread This topic has been viewed 2340 times and has 1 reply Next Thread
Parnell
Sweden
Adding a crawl space afterwards
Hi! Thanks for this great program!
I am trying to add a crawl space after I have designed the other levels (my mistake). So I added a new level with some walls, set elevation to 0 and added the height of the crawl space as elevation value to the other levels (3 levels). All elements, furniture etc. are now correctly elevated but the walls are not elevated. The walls of the ground floor are e.g. still on the ground (and therefore obscuring the crawl space). They should be on top of the crawl space. I have done houses with basements before (negative elevation) but then I have always started with the lowest level. Now I am trying to add it afterwards. What am I doing wrong?
[Nov 23, 2020, 9:44:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Adding a crawl space afterwards
The height of a wall placed in a level is actually the height you set in its modification dialog box + the floor thickness of the level. May reduce the floor thickness or elevate the level above the crawl space a little more.
[Nov 23, 2020, 12:37:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
