United States
Edit length of dimension
Is there a way to edit a ruler ("dimension") to the size I need it to be?
For walls for instance I can edit the wall and enter the length. For dimensions, all I found was to drag it as long as I need it to be. But often it ends up showing 3 decimals, and since the text is in the middle, in case of a long dimension I cannot even zoom in far enough to fine-tune, because the text is no longer in my screen.
It would be nice if I could right click, modify, and enter the exact size. Or if this is already possible and I just didn't find how to do it, I would appreciate some help.
I would need this to draw the perimeter of the property around the house.
Romania
Re: Edit length of dimension
You have to read this: this and/or this
---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law (Greer's Third Law) When all else fails, read the instructions.Murphy's Law
The version 7.2 now includes a dialog box which lets you modify start and end points of a dimension as well as other parameters.
