Canada
Cut out tool for any object?
Is there a way to make a cut out through everything: not just a wall? The reason is put 45 degree wall sheathing planks on a wood construction 3D build without having to add triangles on the end of each one where there is a wall end, or window or wall opening. See picture for details
Re: Cut out tool for any object?
Only walls and rooms can be cut out by doors / windows and staircases respectively.
