Belgium
SH3D on Ubuntu 20.04 LTS
I have resinstalled 2 PC's with Ubuntu 20.04 LTS the first thing i installed was SH3D because I want to avoid any issues
on My Desktop it works fine.
done the same on my laptop and SH3D doesn't start from the terminal it says command not found while i'm in the folder HOW can I diagnose what is going on, what info do you need
Belgium
Re: SH3D on Ubuntu 20.04 LTS
On my laptop installed SH3D as per download page i.e. extracted files to / and maintained the directory structure of the archive - checked permissions for executable and behaviour = run software => doubleclicking Sweethome3D run software starts but the nothing happens => for terminal : cd to SH3D directory then SweetHome3D results in command not found
java version : openjdk version "11.0.9" 2020-10-20 OpenJDK Runtime Environment (build 11.0.9+11-Ubuntu-0ubuntu1.20.04) OpenJDK 64-Bit Server VM (build 11.0.9+11-Ubuntu-0ubuntu1.20.04, mixed mode, sharing)
What was your exact command to run it from the terminal? You know, you have to start the command with "./"? So the command you have to type in is "./SweetHome3D" (wihtout "").
Pascal
Belgium
I don't want to start it from terminal because the terminal window stays open. Further more it is not listed in the Application selector
I prefer starting it from Nautilus because I know it works, whereas whan I start if from terminal things go wrong and work gets lost. ( I have been working like that since feb/march of this year whan I reinstalled and had the same problem and instability over and over again. Moreover I can save the launcher instance to luncher favourites and i can restart it from the launcher bar
The Bundle in the distro is out of date 5.x( if i'm not mistaken) it's not even worth to install
BTW ============= on my last start in Terminal following errors showed up ... ~/SweetHome3D-6.4.2$ ./SweetHome3D Gtk-Message: 11:28:55.194: Failed to load module "canberra-gtk-module" Exception in thread "pool-8-thread-1" java.lang.NullPointerException at com.eteks.sweethome3d.swing.ImportedTextureWizardStepsPanel$19.run(Unknown Source) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748)
Belgium
this is my .desktop file (on both machines disk config, mount points and directory structure are identical)
[Desktop Entry] Version=1.0 Name=Sweet Home 3D 6.4.2 GenericName=Interior 2D design application with 3D preview GenericName[de]=Innenraumplaner Comment=Interior design Java application for quickly choosing and placing furniture on a house 2D plan drawn by the end-user with a 3D preview Exec=/home/derek/SweetHome3D-6.4.2/SweetHome3D Icon=SweetHome3DIcon StartupNotify=true StartupWMClass=com-eteks-sweethome3d-SweetHome3D Terminal=false Type=Application Categories=Graphics;2DGraphics;3DGraphics; Keywords=interior;design;2D;3D;home;house;furniture;java;
SweetHome3D will now appear in your applications. You're right, starting from the terminal is not an acceptable option. But you could even start a software from the terminal with a .desktop with the corect exec line.
Pascal
Belgium
Got it to work from Nautilus
I edited the .desktop in /usr/share/applications and corrected the path to /home/derek (replaced the capitals)
I changed the properties of the file , and in permissions switched off the executable flag and open with text editor.
In Nautilus : Preferences -> Behavior -> Executable Text Files to Ask what to do.
Stopped Nautilus , and rebooted Ubuntu , started Nautilus
In Nautilus : Preferences -> Behavior -> Executable Text Files to Run executable. I changed the properties of the file , and switched ON the executable flag of SweetHome3D and open with Run software.
and it starts and i could append it to favorites (dock)
WOW! I tried to help you, and now you showed me how to do it! NICE! Next time you do not have to reboot Ubuntu, you only quit Nautilus from the terminal with "nautilus -q". And then start Nautilus from where you do it normally.
Pascal
