Re: Cannot open File
The 9 files you sent me are full of zeros, i.e. they contain no usable data! Are you sure there are still some valid files on the disk where you found them?
The files are more than corrupted, they contain absolutely no data. If I were you, I would check if the hard disk where you stored these files is not dying.
Hello Puybaret I'm also having problems opening a sh3d file I saved earlier. I was doing a bit of house keeping when I changed a file to "open file with" (different to sw3d file) in file properties, the file type of this particular sh3d file also changed, after searching a bit, I managed to revert the process, ut now it won't open in sh3d. Can you please help. Many thanks Juan
PS: As in previous posts, I have checked the Users/Appdata.... folder but there is nothing there
