Previous Thread This topic has been viewed 3175 times and has 2 replies Next Thread
harbinger
US
Preventing 'smeared' textures?
I started using Art of Illusion to create the models I need, but I'm having a problem with textures.
Does anyone know what you have to do to prevent textures from sliding or smearing on a face, like this?:
[Edit 1 times, last edit by harbinger at Sep 23, 2020, 11:51:42 PM]
[Sep 23, 2020, 11:50:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Preventing 'smeared' textures?
This can avoided when texture coordinates are set on a 3D model and you modify textures with the Material modification dialog box.
Otherwise you could also use a thin box for that part.
[Sep 25, 2020, 9:35:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
harbinger
US
You're right. I found out that in order to avoid this you MUST apply a texture to that face before exporting to OBJ.
If anyone is using AoI, make sure if you apply a texture (rather than a material), do not set it to Projection. This will smear the texture you applied on certain faces of the outgoing model.
(I've not begun using Materials, so I dont know of the settings there...)
[Sep 26, 2020, 12:11:28 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
