Total posts in this thread: 12
Previous Thread This topic has been viewed 19506 times and has 11 replies Next Thread
xmastree
Philippines
linux issues.
Hi all, hoping someone can help here.
I had computer issues. I ended up installing linux and all's well.
However, when I installed SH3D, I noticed a slight difference in the way it behaves compared to the Windows version.
Compare these two images:
The first one was from when I was running Windows, the second one is the current view.
Is this just how things are in linux, or am I missing something?
The 3D view is fine:
[Aug 10, 2020, 3:15:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: linux issues.
Select the Top view option in preferences pane.
[Aug 11, 2020, 4:51:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
xmastree
Philippines
Re: linux issues.
Thanks for your reply. I found the relevant section in the preferences, but it's greyed out.
https://imgur.com/i3ODoHR.png
[Aug 13, 2020, 11:47:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
UbuntuBirdy
Re: linux issues.
Have you installed the latest video driver? If so, try installing another video driver. Have you installed the open source driver - try it with the proprietary one. Or vice versa.
Pascal
[Aug 13, 2020, 5:40:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
xmastree
Philippines
Re: linux issues.
I'm just using whatever driver came with the distro. It's Mint 19.3 and Intel video, not sure there are any other drivers available.
[Aug 17, 2020, 2:06:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: linux issues.
Try the other script SweetHome3D-Java3D-1_5_2 provided with Sweet Home 3D installer.
[Aug 17, 2020, 2:59:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
xmastree
Philippines
Re: linux issues.
Other script? I don't see one. I installed it from the repo, using the software manager.
https://imgur.com/CWBU6LA.png
The version on the website seems much bnewer, I'll try that instead.
[Aug 18, 2020, 1:54:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
xmastree
Philippines
Re: linux issues.
Well, we appear to have a solution. I downloaded the latest version, 6.4.2, ran it using the other script, found the top view no longer greyed out and bingo!
Some textures missing, but that should be an easy fix.
Incidentally, just running ./SweethHome3D rather than ./SweetHome3D-Java3D-1_5_2 also seems to work correctly.
[Aug 18, 2020, 2:19:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GerHas
Re: linux issues.
I think I found the solution for the "greyed-out top" view icon problem.
/usr/share/sweethome3d/sweethome3d.sh script contains, upon install via repository, the java option:
-Dcom.eteks.sweethome3d.j3d.checkOffScreenSupport=false
set it to true and top view icons behaves normally again.
Please let me know if I need report this to ubuntu launchpad or that this is the right channel
[Jan 15, 2021, 1:35:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: linux issues.
com.eteks.sweethome3d.j3d.checkOffScreenSupport is equal to true by default. Why did they decide to set it to false?!?
Setting it to false is reserved for exceptional cases, like explained in the FAQ Sweet Home 3D crashes when I want to edit preferences, print, create a photo or create a video. What can I do?
Setting it to true will remove some errors for a few users, but all the other users won't have top view icons or won't be able to the 3D view and generate photos at the two first quality levels (even if that could be replaced by screenshots if needed).
[Jan 15, 2021, 4:55:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
