US
Here are a few translucent textures
Submitted for your approval, here are some textures that have their transparency value reduced so that they can be used as textures or materials for lampshades, drapes, etc.
I was having problems showing see-through light on lampshades and discovered in another thread here that you can apply partially transparent PNG textures. I found that the best transparency or Alpha value is between 80 and 95%. However the light source still shows through instead of spreading diffusely through the material. For that I will probably need to experiment with the values in the MTL file for the object.
But these textures will still look nice and can show what kind of texture manipulation you can use in Sweet Home. A few of them will look great on sconces, and others will look great on partition screens.
If these inspire you to create some of your own, feel free to share them here.
