Total posts in this thread: 5
Previous Thread This topic has been viewed 1427 times and has 4 replies Next Thread
ryanburkett
Trim the end of a curved wall
I designed a curved staircase that is hidden behind a book case. To meet the space requirements, I would like to trim the end off of the curved wall to provide better access to the stairwell. Every time I try to move the endpoint of the wall, the shape changes. How can I do this?
[Jul 17, 2020, 10:42:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Trim the end of a curved wall
There's no easy way to shorten a curved wall. Best you draw a new wall.
Mark starting and end point of your wall.
Delete old wall & draw a new wall from/to the marked points.
Redefine the curve.
[Jul 18, 2020, 6:28:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
No need for a new wall.
Imagine the full 360 ° circle of your curved wall. Find out how many degrees you want to shorten it with, and subtract that number from your current arc extent measure. Then your wall will snap into place.
[Jul 18, 2020, 12:24:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ryanburkett
This worked! Thank you Hans!
[Jul 24, 2020, 12:32:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ryanburkett
This changed the arc and would not work, but thank you for the attempt!
[Jul 24, 2020, 12:33:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
