Photo-video rendering plug-in - crash
With none answer, I decided to create this new thread.
Pictures are better than words.
The file : 65 MB compressed. Night texture in view 3D
The parameters
After launching, sh3d calculates during 10 sec and gives this picture.
1 sec after this picture, SH3D crashes down violently !!!
Why ?
NB : same file at noon = same crash same file with another texture for the sky = same crash same file with puybaret's yarafay plugin = same crash...
same file with sunflow method is OK with PVR 1.9 same file with Standard rendering is OK... .
Re: Photo-video rendering plug-in - crash
Standard procedure for me is: - Delete half of your models and render. If it renders OK, you know that one of your models is at fault. - Repeat the process until you have the culprit.
NB: I see a tree in your image. Trees can cause havoc during r endering.
YafaRay is programmed in C++ not in Java, so in case of problem, it might make Sweet Home 3D crash much more easily than a Java library like SunFlow. Does it work with YafaRay rendering plug-in?
... Does it work with YafaRay rendering plug-in?
Read better... or clean your pair of glasses .
Then try to make a SH3D as simple as possible that shows the problem and send it to me, because I couldn’t reproduce your issue the last time you mentioned it.
