Previous Thread This topic has been viewed 1318 times and has 2 replies Next Thread
s_koch
DE
Create objects from walls?
Hi and good morning to all,
I am on a good way and created some simple objects from walls.
For example a half-round counterdesk.
But my question: does someone know an "easy" method to solve this:
when I use different colors for left and right side of the wall, I end up in the exported and reimported object with different "materials".
What is perfect, as I want to use different textures for the front and on the rear side of my counterdesk.
But on the top and on the ends, there are those half-and-half colors (or textures), what I can easily solve with an extra very thin wall at the ends.
But for the top, I need to create an object now - some kind of top-plate ("tabletop") what has this specific form of a half-round plate.
And so I search for an "easy" method to create such "top-plate" from the wall, or maybe from the object in a second step...
ups, just getting a phonecall, I try to show some screenshots
thanks !!!!
[May 28, 2020, 7:44:53 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Create objects from walls?
Make your walls just a few cm high and insert a room that acts as the counter top.
Export and import as furniture.
[May 28, 2020, 8:46:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
s_koch
DE
Wow,
so, also rooms can be used for a creation of objects.
This "problem" is solved, let´s wait for the next ;-))
Many thanks again!
I really appreciate your help.
[May 28, 2020, 11:10:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
