Total posts in this thread: 2
Previous Thread This topic has been viewed 4767 times and has 1 reply Next Thread
videogreg@hotmail.com
Trying to build an underground structure
I have built a basement level (by creating a new level and making it a negative elevation) I have the dimensions, floor, walls and access slope (a ramp) all completed. How can I show the ground level render and have my ground level texture cover the underground structure I created? When I view at my 0 elevation level the below ground room has an open top and I can see inside.
If I create a floor at ground level (covering this space) I cannot have the ground level image flow seamlessly over the new floor area.
[Apr 18, 2020, 5:40:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Trying to build an underground structure
Either you select the upper level, or you select the 3D View > Display all levels menu item.
[Apr 20, 2020, 2:07:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
