Kenya
Application Crash
Hi folks
I'm new at this application, actually i started using it yesterday.
Today i experienced a weird issue in different situations.
1. Opened the fie i worked on for 16 hour yesterday, then i open a new file - Program crash 2. restarted and got both files open, and copied some objects from yesterday to my new file. about 15-20 selected objects. 2 sets of copying worked, the third crashed the program. 3. Yet another try with the third set (yes i save often), copy / paste worked, but when i tried to move the group of objects,program crash.
Nothing has changed since i finished working last night so i can't believe it's hardware fault, i just shutdown the laptop yesterday and started it this morning.
I run windows 10 on a MSI machine with core I7 with 16Gb RAM. all updated.
Re: Application Crash
Maybe you use some large 3D models. If you run Sweet Home 3D in 32 bit (see About dialog box), try to reinstall the program in 64 bit if possible (select 64 bit option in the installer screen used to choose the installation folder).
United States
Please help me Why showing this massage "the application is not responding. The program may respond again if you wait" while closing the application." How may i solve this?
