Features
Previous Thread This topic has been viewed 465 times and has 2 replies Next Thread
elpigouillo
Geodesic Dome
I'm looking for Geodesic Dome
Did someone made a model like wall or other ?
Thanks for all.
[Mar 31, 2020, 12:27:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SeppoV12
Finland
Re: Geodesic Dome
I think that it is impossible to create (in SH3D) geodesic dome that has wall properties. That is because walls in SH3D are always vertical.
And this means that you can not build geodesic dome (for example) with triangular wall pieces.
Otherwise walls can be even ring-shaped (two arcs 180 degrees each or 90 +270 degrees (270=max. value for arc) and so on..)
If you don't need to add doors and windows, you can download domes from 3D Warehouse (https://3dwarehouse.sketchup.com/search/?q=dome).
You can also create ring-shaped wall and add that dome on top of it if that exact shape is not absolute requirement.
Hope that I have understood your meaning right..
Seppo
[Apr 15, 2020, 5:29:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Re: Geodesic Dome
Thanks for all.
Few months ago, I realized this :
PS : I have some cupola/dome in my store, just ask me in PM wink
Back to 6.1.2 (6.2 & 6.3 too heavy) and nothing else - W10 64b
Asus TUF Z390 , Intel Core i9-9900K (3.6 GHz) , Chipset Z390 Exp, RAM 32 Go DDR4 3000 Mhz, SSD M.2 512 Go + HDD 3 To,
MSI GeForce RTX 2080 8Go
[Apr 15, 2020, 5:55:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2020 eTeks - All rights reserved
