High priority possibility to break the line of the name's field of furniture
This topic has been viewed 3412 times and has 3 replies
Thread status: Active
Post Reply New Topic
Friedrich
Country: germany
Post by Friedrich »
hello together, I'm looking for a possibility to break the line of the name field of furniture name in several lines in order to get enough place in the plan:
line 1: "This is a furniture"
line 1: "This is"
line 2: "a furniture"
who could help me?
Thanks!
Friedrich
User avatar
Country: Paris, France
Contact:
Re: possibility to break the line of the name's field of furniture
Post by Puybaret »
This is not possible for furniture name. If you want to write on multiple lines, add texts with the tool designed for that.
Friedrich
Country: germany
Post by Friedrich »
Hello Emmanuel, thank you for your kind reply. My problem is: I have plans of several building levels. In this plans I have designed Infrared heating panels on the ceiling. I want to check which are the technical attributes of those panels in order to show them to the electrician. But the "names" of these panels are to long:
HVH600 119,2x59,2 600W
they are overpassing the sizes of the panels and are disturbing the plan.
Therefore I should have the names in this format:
HVH600
119,2x59,2
600W
I could do this with an extra text field. But this field should be connected to the heating panel on order to be able to move them together. Unfortunately I am not able the create a group with the text and the object.
Is there any solution?
aleksei5698
Post by aleksei5698 »
HVH600
119,2x59,2
600W
Hello Friedrich
Have you found solutions to this problem?
Indeed, it is very inconvenient that there is no way to display the name on
multiple lines. And the text with furniture, as you noticed, is not grouped.
Who is online
Users browsing this forum: Google [Bot], MSN [Bot]
