Total posts in this thread: 4
Previous Thread This topic has been viewed 6953 times and has 3 replies Next Thread
jhonnca
españa
sweet home 3d does not start correctly in the manjaro operating system (arch-linux)
apparently there are conflicts with the java package.
terminal exit when launching sweet home 3d application.
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by javax.media.j3d.JoglPipeline (file:/usr
/lib/sweethome3d/java3d-1.6/j3dcore.jar) to method sun.awt.AppContext.getAppC
ontext()
WARNING: Please consider reporting this to the maintainers of javax.media.j3d
.JoglPipeline
WARNING: Use --illegal-access=warn to enable warnings of further illegal refl
ective access operations
WARNING: All illegal access operations will be denied in a future release
Inconsistency detected by ld.so: dl-lookup.c: 111: check_match: Assertion `ve
rsion->filename == NULL || ! _dl_name_match_p (version->filename, map)' faile
d!
link to the topic within the manjaro forum.
https://forum.manjaro.org/t/sweet-home-3d-does-not-start-correctly/130724/3
[Mar 21, 2020, 1:57:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: sweet home 3d does not start correctly in the manjaro operating system (arch-linux)
These are just warnings
[Mar 22, 2020, 8:22:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jhonnca
españa
so how can i offer useful data to solve this?
believed that it was just a java bug in the manjaro repositories (arch-linux) and that updating or replacing the repository would suffice.
[Mar 22, 2020, 11:19:53 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jhonnca
españa
the problem was resolved for the Manjaro-Kde plasma system.
To test it, you must run sweet home 3d through the terminal:
command line to execute:
SWEETHOME3D_JAVA3D = 1.5 sweethome3d
link to the open topic in manjaro where you can find more information.
https://forum.manjaro.org/t/solved-sweet-home...-start-correctly/130724/7
[Mar 22, 2020, 7:23:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
