Total posts in this thread: 6
Previous Thread This topic has been viewed 5264 times and has 5 replies Next Thread
rbell777
United States
Drawing in a scale suitable for small objects, like a cabinet
I want to use Sweet Home 3D to draw smaller projects, like a cabinet that is only a couple feet wide or less, for example. However, the default Drawing Scale on screen is obviously only for a large room or an entire home. I've tried many other drawing programs, but they don't show the dimensions AS you're drawing a wall, line, etc.
[Mar 16, 2020, 12:21:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hal9000
Spain
Re: Drawing in a scale suitable for small objects, like a cabinet
As a workaround, you can draw up-scaled versions of the small objects, lets say measures x10 or x100, and then down-scale to the correct size before save the definitive result.
[Edit 1 times, last edit by hal9000 at Mar 17, 2020, 1:08:02 PM]
[Mar 17, 2020, 1:07:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sure, but the real problem is the zoom level. The zoom should be next to infinite, like it is in most other programs. Then we wouldn't need this workaround.
[Mar 22, 2020, 7:03:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The drawing of a piece of furniture in its selection rectangle at large zoom factors that was fixed in the version 6.1 enables larger zoom factors now, and I was planning to double the maximum allowed zoom in the next version. At the maximum value, 1 mm would be 1 pixel wide at screen.
That should be enough right?
[Mar 23, 2020, 8:57:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
smile Re: Drawing in a scale suitable for small objects, like a cabinet
Right!
[Mar 24, 2020, 8:46:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The version 6.3 comes with a maximum zoom where 1 mm = 1 pixel.
[Apr 16, 2020, 8:59:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
