Total posts in this thread: 6
Previous Thread This topic has been viewed 2268 times and has 5 replies Next Thread
2manyprojects
US
Launch multiple instances of SweetHome3D?
I searched around and could not find an answer.
Is there a way to launch multiple instances of SweetHome3D?
I am using the linux version and launching SweetHome3D-Java3D-1_5_2.
Attempts so far to launch multiple instances, even from different source locations just shows the one currently running instance.
Thanks,
M-
[Feb 23, 2020, 6:09:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Launch multiple instances of SweetHome3D?
It’s not possible without dirty tricks, but I could add an option for that in a future version. Why do you need that?
[Feb 25, 2020, 6:07:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
rrraf
I would also love that in order to be able to launch (night long) "multiple photo rendering" in multiple designs/files. Unless there's another way to achieve this?
Regards
[Mar 1, 2021, 12:26:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I added the com.eteks.sweethome3d.singleInstance system property in Sweet Home 3D 6.5 to make each launch of the application run in a separated process when set to false.
To use this property, add the line
-Dcom.eteks.sweethome3d.singleInstance=false
to a file named SweetHome3D.l4j.ini and stored in Sweet Home 3D installation folder.
[Mar 3, 2021, 6:55:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Would that enable us to use 2 instances of sunflow too?
[Mar 3, 2021, 10:07:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Yes, but both instances will try to use all the cores of the CPU, so I’m not sure it will be efficient.
[Mar 3, 2021, 10:11:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
