What are these weird light lines?
This topic has been viewed 4899 times and has 6 replies
Thread status: Active
Post Reply New Topic
gregoryx
Post by gregoryx »
Finally starting to dial the lighting in (thank you @ceciliabr and other). I'm pretty sure the ceiling lights I'm using came from @ceciliabr and they helped me solve the mess I had originally.
But after adding them, I get this light line along the ceiling - and around the ring of the lights as well. I can't figure out where it's coming from I've tried modifying the lights but I guess I'm missing something in there.
Ideas?
https://www.dropbox.com/s/yrcoq5i1qtgv8 ... 20sink.png
(Hoping that Dropbox link works for the PNG)
User avatar
Country: Paris, France
Contact:
Re: What are these weird light lines?
Post by Puybaret »
I think these lines may appear when you create a photo with YafaRay rendering plug-in. It's like sun light would be able to go through the very very thin space between walls and the ceiling.
I should find a way to automatically fix that, but it's not so simple. Meanwhile, you could chose a night time in your case.
gregoryx
Post by gregoryx »
Thank you, @Puybaret. It looks the same at 2am. I'll try back to the old renderer and see if it's there still. I'll also try placing a big, black "roof" (box) over it to see if it helps.
User avatar
UbuntuBirdy
Country: Switzerland
Contact:
Post by UbuntuBirdy »
Are there invisible light panels on this ceiling? If so, are they flush with the ceiling? If so, place them a little bit deeper (the same amount your highlighted edges are in height).
Pascal
gregoryx
Post by gregoryx »
Thanks, @UbuntuBirdy. That was my first thought as well. I'm using a recessed light thing that @ceciliabr built and shared. I tried recessing it further and changing the shape of it. It /seems/ like that has to be the cause... but it hasn't worked to fix it.
I think getting rid of those got rid of the problem; but I'll have to go back and review. If I'm the only one seeing something like this, I'm clearly doing something wrong with those ceiling can fixtures. 😒
enkonyito
Post by enkonyito »
@gregoryx
Ideas?
As Puybaret said, this problem occurs with the YafaRay rendering engine.
My tip is to add a lower level and a higher level to the virtual visitor's position by displaying all the levels in the 3D view so that the floors fill these interstices.
Enko
EnkoNyito
User avatar
Contact:
Post by Puybaret »
As explained here, this issue is fixed in the version 1.4.3 of the YafaRay rendering plug-in.
Thanks for your patience.
