Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Roadmap |
| Print at May 21, 2012 10:00:12 PM |
| Posted by ichklaus at Nov 15, 2007 4:10:00 PM |
Roadmap Is there a roadmap? When approximately will version 1.3 be launched? In January? I´m looking forward to it... Good job puybaret! Keep it up! Best wishes! Klaus [Note: this thread was started on sourceforge.net forums] |
| Posted by Puybaret at Nov 15, 2007 6:22:00 PM |
Re: Roadmap Thank you for launching this discussion about Sweet Home 3D roadmap. I wanted to create a web page for it, but finally this forum is the easiest way. Here's the features roadmap I've got in mind at this time: - v 1.3 : creation and modification of home rooms, with textures applicable to room's floor and cellar - v 1.4 : ergonomic stuff : automatic depth of windows and doors placed on walls, stick and orientate objects to the approach of a wall, better management of magnetism - v 1.5 : management of lights - v 2.+ : management of multiple floors, roofs, export to other formats... v 1.3 shouldn't be available before February or March 2008 (I have to earn some money first ;-). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D developer |
| Posted by Puybaret at Feb 10, 2008 8:43:00 PM |
Re: Roadmap Just this message to announce that probably, Sweet Home 3D v 1.3 won't be available before this summer, because I don't have enough free time right now to program more things that maintenance releases. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D developer |
| Posted by jeroen_roeterd at Mar 4, 2008 7:36:00 PM |
Re: Roadmap Hello, Just letting you know that I discovered your application just hours ago and like it very much. The features you name in later releases would make it much better (spec. floor and cellar textures). Keep up the good work (after earning a living of course ;-)) Greetings form the Netherlands, Jeroen |
| Posted by Wolf_Skafte_Zauss at May 30, 2008 2:08:00 AM |
Re: Roadmap Hi there I love your project and was wondering if there is any way of of making it a web based application. My idea is to offer our customers the facility to create their own floor plans on-line. Any information on this would be appreciated and if we could make this happen then I would be happy to become a sponsor for your project. Have a great day Wolf Skafte-Zauss Contemporary Door & Cabinet Hardware specialists. http://www.bluewolf.net.au 1300 738 936 Fax: 02 9012 0193 |
| Posted by Puybaret at Oct 8, 2008 12:08:00 PM |
Re: Roadmap From the description of versions 1.3 and 1.4 at http://sweethome3d.sourceforge.net/history.html , you may guess that the roadmap proposed one year ago changed a little. ;-) So, here's the new roadmap I've got in mind at this time: - v 1.5 : creation and modification of home rooms (with textures applicable to room's floor and cellar), and creation of free text labels in the plan - v 1.6 : ergonomic stuff : automatic depth of windows and doors placed on walls, stick and orientate objects to the approach of a wall - v 1.7 : management of lights - v 2.+ : management of multiple floors, roofs... Meanwhile, I might also test an on-line applet version of Sweet Home 3D. I prefer to promise no delivery date, but be reassured, I'm still spending a lot of time on Sweet Home 3D development. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D developer |
| Posted by vincecat at May 7, 2009 12:42:00 AM |
Re: Roadmap Bonjour monsieur Puybaret. Un grand merci pour votre travail. J'utilise Sweet Home 3D depuis la v1.3 et je suis toujours autant impressionné par la simplicité de SH3D au regard de sa puissance. La dernière petite merveille, l'online applet, est sur mon site (ecolonomiqhome.free.fr). Elle fonctionne aussi bien que le reste. J'ai un peu honte, surtout que je ne vous ai pas encore fait de don, de vous demander un ajout à votre roadmap: - pourriez-vous ajouter l'export DXF ou DWG en plus du SVG. Les raisons de cette demande sont l'échec de conversion du SVG, créé par SH3D, en DXF via Inkscape (je peux vous faire parvenir les fichiers ainsi que les messages d'erreur d'Inkscape si vous le souhaitez). Le format DXF est le plus commun pour l'import de plan dans les logiciels du bâtiment comme Alcyone+Comfie+Pleiade (simulation thermodynamique) et Dialux (simulation d'éclairage). En tout cas, que vous le fassiez ou pas, un grand merci d'avoir créé SH3D. Cordialement. |
| Posted by Puybaret at May 7, 2009 2:43:00 PM |
Re: Roadmap Pour ne pas alourdir le logiciel, je ne pense pas ajouter d'autre format d'export dans un avenir immédiat (à part peut-être pour les images de la vue 3D), mais ce genre d'exportation pourrait être réalisé à l'aide d'un plug-in (y'a-t-il un volontaire dans la salle ? ;-). Il existe peut-être aussi un convertisseur autre que Inkscape qui fonctionne... Vous pouvez aussi signaler le bug à l'équipe d'Inkscape pour qu'ils essaient de le corriger. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D developer |
| Posted by vincecat at May 7, 2009 11:19:00 PM |
Re: Roadmap Je comprend. Pour le convertisseur qui fonctionne, oui il y en a un: ivcon (un executable en ligne de commande trouvé ici). Mais la visu sous Comfie, confirmée avec Cadviewer, du DXF obtenu m'a vraiment surpris. Inexploitable dans mon cas. Merci et bonne continuation pour la v2. Cordialement |
| Posted by Puybaret at Aug 7, 2009 11:55:00 AM |
Re: Roadmap Now that version 2.0 is out, here's a list of the main features that will probably appear in the 2.+ releases: - Grouping/ungrouping furniture - Better furniture catalog pane for catalog containing many pieces - New Display menu to let user choose which pane to display - New wizard to create 3D models from pictures applied on the faces of a cube, sphere or cylinder - Creation of videos from a virtual visit - Improvement of lights management - Management of levels - Management of roofs - Manage portability to simplify the moving of Sweet Home 3D ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D developer |
Current timezone is GMT May 21, 2012 10:00:12 PM |
