Print at Jul 9, 2020, 7:55:13 PM View all posts in this thread on one page
Posted by dorin at Jan 7, 2019, 8:26:13 AM
Multiple paste & Distribute on high (on z axes)
Until we have a stairs generator for me are more useful this two additional tools:
1. Multiple paste... or Paste special...
-Select an object or more
variant a
-Edit->Multiple paste...
-An popup dialog "How many copy?"
-Insert an number (>0)->"OK"
or
variant b
-Edit->Paste special...
-An popup dialog with few entries
--"How many copy?"
--"Distance on x, y, z"
-Insert the desire numbers (>0)(for axes in cm)->"OK"
result an numbers of objects inserted in the plan.
In this way I don't need to ctrl+v for 50 or 374 times to insert the same object (steps for staircase or chairs on a theater)
2. Distribute on high (on z axes)
-Select and modify the elevation of an object to maximum need
-Select the (previously created) objects (>=3)
-Right click->Align and distribute...->Distribute on high
With this two new option is more easy to create staircases but not only.
Posted by dorin at Apr 29, 2019, 9:52:56 AM
Re: Multiple paste & Distribute on high (on z axes)
Message in a Bottle -The Police - 1979
As I say "If You don't like it AS IS than DIY".
I've start to write an plug-in for this but I encounter a problem:
Look at the screenshot:
The items are added in 3D and in Furniture list but only the last are draw in 2D.
If I save the file and reopen the items are there but is not what I want or expect.
Here is the code responsible for this:
UndoableEditSupport undoSupport = plugin.getUndoableEditSupport();
undoSupport.beginUpdate();
// HomeView view = plugin.getHomeController().getView();
float dx = 0;
float dy = 0;
int step = (int) stepsField.getValue();
float Xo = (float) xField.getValue();
float Yo = (float) yField.getValue();
for (int p = 1; p <= step; p++) {
dx += Xo;
dy += Yo;
// Attempt add/move items
plugin.getHomeController().getPlanController().addItems(items);
plugin.getHomeController().getPlanController().moveItems(items, dx, dy);
// Attempt to use drop or paste
// plugin.getHomeController().drop(items, null, dx, dy);
// plugin.getHomeController().paste(items);
undoSupport.postEdit(new AbstractUndoableEdit() {
I mess something but I don't know what.
I've catch my ears and maybe someone read this and drop me an lifeline sad
Posted by Puybaret at Apr 29, 2019, 12:17:35 PM
Each item added to home must be unique, and you have to duplicate the items you want to add, for example using their clone method. To ensure that future redos work correctly, they should be cloned only once, and not in the redo method.
Posted by dorin at Apr 29, 2019, 1:40:54 PM
Thank You, Emmanuel!
You find my bottle very quickly. hugs
I remove (comment) my undo method => same result.
I change clipboard whit selected => same result.
I'll try to change the principle from "for" to "wile" or other kind of.
Maybe I'll find a way to convince SH3D to take care to all items I insert.
Nothing is impossible but not all are easy.
The computer MUST do what I need. raised eyebrow
Posted by dorin at May 16, 2019, 9:16:15 AM
I finally convince SH3D to accept my opinion.
The Paste special...(multiple Ctrl.+v) are working somehow.
Now I tray the distribute elevation.
Off course Murphy' Law are present:
solving a bug I generate other 3 and discover another 5.
Well, I don't have time to be bored.
