Print at Apr 19, 2019 11:18:17 AM View all posts in this thread on one page
Posted by Dadv at Dec 9, 2018 9:02:33 AM
Add Name to the walls
this will be a good addition if you could add a name field on the walls properties like the rooms.
This name should be optional.
It should be in the same orientation than the wall (if it is curve, then it should be tangent of the curve).
It should be in the same direction of the wall on the top side.
3 reasons i need that :
- When i try to select a wall that is cross by other wall, it's hard to detect the good one.
- It will be more easily to write the context of the wall. actually i add a label and try to make it follow the same direction.
- I'm creating a tool that get all the elements of a SH3D file and actually, the wall are only identified by an arbitrary Id.
Thanks
