Print at Aug 18, 2019 7:39:48 AM
Posted by EZBUZZSAW at Nov 23, 2017 5:15:08 PM
Sloped walls and tilted walls
So I am having a problem with a sloped wall on a barn home design. I was able to make the sloped walls for the ends of a typical barn roof but the upstairs wall that is also the roof line needs to tilt in to meet the sloped walls. It is like the upstairs in this Barndominium inserted. Is there a way to do this? I have been searching for hours so it is probably simple and right in front of my eyes...
https://www.google.com/url?sa=i&rct=j&...&ust=1511543590015399
Posted by hansmex at Nov 24, 2017 8:31:31 AM
Re: Sloped walls and tilted walls
Whether or not the question is asked in the right place, unfortunately, I don't understand the question.
1 - The end facade can be made by drawing a wall and splitting it it in 4 sections. Two sections slope up, two sections slope down.
2 - The roof can be made by drawing a wall in 6 parts, as explained in this tutorial (chapter 3). You than export and import the walls, and rotate the object to give it the correct orientation to function as a roof.
Posted by bdfd at Nov 24, 2017 11:55:02 AM
perhaps like this ?
only 6.2 and nothing else - W10 64b
Asus TUF Z390 , Intel Core i9-9900K (3.6 GHz) , Chipset Z390 Exp, RAM 32 Go DDR4 3000 Mhz, SSD M.2 512 Go + HDD 3 To,
MSI GeForce RTX 2080 8Go
Posted by hansmex at Nov 24, 2017 11:59:43 AM
bdfd, that's perfect, exactly what I tried to describe. (even though I am not 100% sure if it is what Ezbuzzsaw asked)
