Print at Sep 18, 2019 5:51:33 AM View all posts in this thread on one page
Posted by hoangtrunglien at Jun 25, 2017 9:13:29 AM
How to edit a room
I have created a room and the size of it is now shown. How can I make the room larger or add another room to it? I do not know the keys I need. Dragging the edges does not leed to what I want.
Thanks for your help.
Posted by bdfd at Jun 26, 2017 6:00:36 AM
Re: How to edit a room
Try to cancel the 'magnetism' option to update the room,
or
Add new walls for new room...
only 6.2 and nothing else - W10 64b
Asus TUF Z390 , Intel Core i9-9900K (3.6 GHz) , Chipset Z390 Exp, RAM 32 Go DDR4 3000 Mhz, SSD M.2 512 Go + HDD 3 To,
MSI GeForce RTX 2080 8Go
Posted by Puybaret at Jun 26, 2017 9:20:03 AM
I guess you moved the walls, expecting the room points would follow but this is not how Sweet Home 3D works. Select the room surface and move the points to the new wall corners, and you'll see that magnetism will help you place them easily on the corners. You may also delete the room surface and create it again with the room creation tool.
