Print at May 16, 2022, 11:59:55 AM
Posts: 43   Pages: 5   [ Previous Page | 1 2 3 4 5 | Next Page ]
Posted by hansmex at Sep 13, 2014, 9:53:40 AM
Re: Sweet Home 3D 4.5
Emmanuel,
The tree model now imports correctly.
The chair model also imports correctly.
The old house model cannot be imported correctly, despite using the trick you described:
- use original 3ds file, convert images to jpg, delete original tif, then rename jpg to tif.
- I also tried to change the 3ds file: using a text editor I changed all references of tif to jpg, then I changed images to jpg. No success.
This tractor also imports correctly.
This tarantula is not recognizes as a valid 3ds file.
This excavator does not import correctly. There are still some shifted parts. Colours are missing, but materials are defined.
Conclusion: It's getting better, but not yet perfect :-)
Thank you for your time and effort.
Posted by Puybaret at Sep 13, 2014, 2:43:10 PM
Thanks AruN and Hans for your tests smile
I wouldn't try to edit a 3DS file with a text editor, because it contains various data used to validate file content length. But no problem to view its content to find out the images files it references.
Did you move the images files out of the tex subfolder?
The tarantula can't be imported because the 3DS files doesn't contain any 3D faces (only two lights).
The excavator data is probably incorrect since Autodesk's FBX Converter reports the same issues (like the two models of Model3D.biz I spoke about in the first message of this thread).
Posted by hansmex at Sep 13, 2014, 3:37:25 PM
Emmanuel,
Regarding the old house model:
I tried to change the 3DS file using first gedit, then notepad (Remember, I'm using Ubuntu). In both cases I think the problem is that all kinds of non-printing characters aren't recognized by the text editor, and are changed to incorrect values. The result is that the modified file is useless.
And no, I didn't change the directory of the tif/jpg files.
Posted by YGYL at Sep 14, 2014, 2:34:30 PM
Can you add a feature?
free to rotate objects. It is very important. Very useful. Otherwise, we can only continue to export the model, and then import the model to rotate it.
Posted by Puybaret at Sep 14, 2014, 5:43:09 PM
Sorry YGYL, if it happens, there are very very little chances that it will be in the next version.
Posted by sree.arun.kr at Sep 14, 2014, 8:34:59 PM
Hello Emmanuel sir,
I have little idea that if you are able to convert .3ds to obj and vice versa then using .3ds format is used when compress and save if choose it will compress the file more.
wish to see the features like,
add sub category in furniture library, category in texture library, profile switching, built-in hdr files for rendering and more.
Thanks, and welcome all new updates. peace
Posted by YGYL at Sep 15, 2014, 6:31:47 AM
Thank you.
If you can have 3D text symbols function even better
Unicode has too much text(65000), impossible all converted into 3D models(OBJ 3DS)
Posted by YGYL at Sep 15, 2014, 7:15:21 AM
Also, I think we can add a function, after the texture color processing (changing the texture color)
By adjusting the tone parameters, so that a texture into multiple textures
can save a lot of space. Increased freedom
Posted by YGYL at Sep 15, 2014, 7:45:08 AM
[img]http://s25.postimg.org/e3kwbg5d7/44544.jpg[/img]
Posted by YGYL at Sep 15, 2014, 7:46:42 AM
