Print at Jan 29, 2020 9:42:55 PM View all posts in this thread on one page
Posted by thunder at Oct 8, 2010 9:16:18 AM
Zoom problem in aerial view
Hello everyone,
I have a problem with the aerial view. I can see my design as a miniature in the background but I can't zoom in to display it in a normal size. I tried all buttons available. I can move the design but I can't zoom in to make it bigger.
Thanks for your help !
Regards
Thunder
Posted by hansmex at Oct 8, 2010 9:40:10 AM
Re: Zoom problem in aerial view
Thunder,
Do you have a background image? Check the size of that image.
Also, look in Preferences which units you have chosen.
I once ended up with a drawing 1000 times too big because I had millimeters in one place and meters in the other place.
Posted by Puybaret at Oct 8, 2010 9:48:54 AM
An other tip: use minimum zoom in plan and select all. This might show a tiny object you forgot somewhere in your plan.
Posted by thunder at Oct 8, 2010 10:30:17 AM
Thanks a lot Puybaret, that was the answer: there was a tiny object somewhere far from the design. I deleted it and now the problem is solved.
Posted by thunder at Oct 8, 2010 10:31:39 AM
Thanks hansmex and Puybaret for your quick replies. That was very much appreciated.
