Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: SweetHome does not start anymore |
| Print at May 21, 2012 9:57:44 PM | |
| Posted by Paotr at Jun 8, 2009 9:54:00 PM |
SweetHome does not start anymore After a successful install an use I tried to import a new image (the chimney) sH3d crashed trying to achieve the import. Since then I can't use it anymore when I try to launch it from the command line I get the following error message : yann@Gouelan:~/.SweetHome3D$ javaws SweetHome3D.jnlp netx: Spec version not supported (supports 1.0) I tried to reinstall from the web site but it did not work Any idea ? thanks in advance Config : Sh3D 2.0 - Ubuntu 9.04 - JRE 1.6.0 [Note: this thread was started on sourceforge.net forums] |
| Posted by Puybaret at Jun 8, 2009 9:59:00 PM |
Re: SweetHome does not start anymore > Spec version not supported (supports 1.0) Check your path and which javaws command you really use. This error indicates that you try to run the javaws command that belongs to a Java 1.4 distribution, and not Java 1.6+ distribution. I hope this will help. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D developer |
| Posted by Paotr at Jun 9, 2009 5:22:00 PM |
Re: SweetHome does not start anymore Hi my javaws is located in : /usr/lib/jvm/java-6-openjdk/jre/bin in the same directory as java : yann@Gouelan:/usr/lib/jvm/java-6-openjdk/jre/bin$ ./java -version java version "1.6.0_0" OpenJDK Runtime Environment (IcedTea6 1.4.1) (6b14-1.4.1-0ubuntu7) OpenJDK Client VM (build 14.0-b08, mixed mode, sharing) should I try another java environment and if yes which one ? Thanking ou in advance |
| Posted by Puybaret at Jun 9, 2009 11:04:00 PM |
Re: SweetHome does not start anymore Try Sun JRE available at http://java.sun.com/javase/downloads/?intcmp=1281 ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D developer |
Current timezone is GMT May 21, 2012 9:57:44 PM |
