Print at Dec 5, 2021, 8:12:11 AM
Posted by AlexQ at Aug 9, 2021, 3:26:32 PM
Re: Texture turned out different from Texture applied to cabinet.
Hi Hansmex,
Thank you. With your instructions, I'm able to follow.
https://www.mediafire.com/file/absim0bc2l3l7yy/width_height.jpg/file
But when I tried to change the dimension of the wood texture to 600 mm (width) x 800 mm (height) to fit the other cabinet size. But the model doesn't allows it. It defaults to a square dimension.
This appears to affect the color/texture to some extent. Is there any way to overcome this issue?
Thank you for your prompt response.
Alex Quek
