Posted by boe666
at Nov 29, 2018, 9:35:24 AM
Re: Export HTML5 plug-in
<html> <head> <meta http-equiv="Content-Type" content="text/html; charset=UTF-8"> <title>View home with Sweet Home 3D HTML5 Viewer</title>
<!-- Copy the following scripts in your page header --> <script type="text/javascript" src="lib/big.min.js"></script> <script type="text/javascript" src="lib/gl-matrix-min.js"></script> <script type="text/javascript" src="lib/jszip.min.js"></script> <script type="text/javascript" src="lib/core.min.js"></script> <script type="text/javascript" src="lib/geom.min.js"></script> <script type="text/javascript" src="lib/stroke.min.js"></script> <script type="text/javascript" src="lib/batik-svgpathparser.min.js"></script> <script type="text/javascript" src="lib/jsXmlSaxParser.min.js"></script> <script type="text/javascript" src="lib/triangulator.min.js"></script> <script type="text/javascript" src="lib/viewmodel.min.js"></script> <script type="text/javascript" src="lib/viewhome.min.js"></script>
<style type="text/css"> /* The class of components handled by the viewer */ .viewerComponent { } </style> </head>
<body> <div> <!-- Copy the following canvas and components in your page, changing their size / texts and other values if needed --> <canvas id="viewerCanvas" class="viewerComponent" width="800" height="600" style="background-color: #CCCCCC; border: 1px solid gray; outline:none" tabIndex="1"></canvas> <div id="viewerProgressDiv" style="width: 400px; position: relative; top: -350px; left: 200px; background-color: rgba(128, 128, 128, 0.7); padding: 20px; border-radius: 25px"> <progress id="viewerProgress" class="viewerComponent" value="0" max="200" style="width: 400px"></progress> <label id="viewerProgressLabel" class="viewerComponent" style="margin-top: 2px; display: block; margin-left: 10px"></label> </div> <div style="margin-top: -60px"> <input id="aerialView" class="viewerComponent" name="cameraType" type="radio" style="visibility: hidden;"/> <label class="viewerComponent" for="aerialView" style="visibility: hidden;">Aerial view</label> <input id="virtualVisit" class="viewerComponent" name="cameraType" type="radio" style="visibility: hidden;"/> <label class="viewerComponent" for="virtualVisit" style="visibility: hidden;">Virtual visit</label> <select id="levelsAndCameras" class="viewerComponent" style="visibility: hidden;"></select> </div> </div> <div style="position: absolute; bottom: 5px; text-align: center; width: 95%; z-index: -1"> <a href="http://www.sweethome3d.com">Sweet Home 3D</a> HTML5 Viewer / Version 1.4 - Distributed under GNU General Public License </div>
<!-- Copy the following script to view your home in the previous canvas --> <script type="text/javascript"> var homeUrl = "test.zip"; var onerror = function(err) { if (err == "No WebGL") { alert("Sorry, your browser doesn't support WebGL."); } else { console.log(err.stack); alert("Error: " + (err.message ? err.constructor.name + " " + err.message : err)); } }; var onprogression = function(part, info, percentage) { var progress = document.getElementById("viewerProgress"); if (part === HomeRecorder.READING_HOME) { // Home loading is finished progress.value = percentage * 100; info = info.substring(info.lastIndexOf('/') + 1); } else if (part === Node3D.READING_MODEL) { // Models loading is finished progress.value = 100 + percentage * 100; if (percentage === 1) { document.getElementById("viewerProgressDiv").style.visibility = "hidden";
//All is loaded at this point. //Overall Listener HPC.getHome().addFurnitureListener(function (e) { console.log(e); }); //set the parameter. var UP = HPC.getUserPreferences(); UP.setAerialViewCenteredOnSelectionEnabled(true); // check the value of parameter (to be sure) var UP = HPC.getUserPreferences(); console.log(UP.isAerialViewCenteredOnSelectionEnabled() ); //list all Items. var HOME = HPC.getHome(); var items = HOME.getSelectableViewableItems(); console.log(items);
//listener for mouse viewerCanvas.addEventListener("mouseup", function (e) { console.log(e); var rect = HPC.getBoundingClientRect; var x = e.clientX ;//- e.layerX; var y = e.clientY ;//- e.layerY; //log the x and y console.log('mouse:' + x + ', ' + y );
//log the camera position x,y,z var obj = HPC.getComponent3D(); console.log(obj); var x1 = obj.camera.x; var y1 = obj.camera.y; var z1 = obj.camera.z; console.log('camera:'); console.log('obj: x:'+x1+',y:'+y1+', z:'+z1);
//chceck item closest var obj = HPC.getComponent3D().getClosestItemAt(x,y); console.log(obj); // ALWAYS NULL var obj = HPC.getHome().getSelectableViewableItems(); //list of selectable items. console.log(obj); //select item nr 5 - nothing happend. HPC.getHome().setSelectedItems(["5"]);
//check selected items var obj = HPC.getHome().getSelectedItems(); console.log(obj)
} } document.getElementById("viewerProgressLabel").innerHTML = (percentage ? Math.floor(percentage * 100) + "% " : "") + part + " " + info; }; / var HPC = viewHome("viewerCanvas", // Id of the canvas homeUrl, // URL or relative URL of the home to display onerror, // Callback called in case of error onprogression, // Callback called while loading {roundsPerMinute: 0, // Rotation speed of the animation launched once home is loaded in rounds per minute, no animation if missing or equal to 0 navigationPanel: "none", // Displayed navigation arrows, "none" or "default" for default one or an HTML string containing elements with data-simulated-key // attribute set "UP", "DOWN", "LEFT", "RIGHT"... to replace the default navigation panel, "none" if missing aerialViewButtonId: "aerialView", // Id of the aerial view radio button, radio buttons hidden if missing virtualVisitButtonId: "virtualVisit", // Id of the aerial view radio button, radio buttons hidden if missing levelsAndCamerasListId: "levelsAndCameras", // Id of the levels and cameras select component, hidden if missing /* level: "Roof", */ // Uncomment to select the displayed level, default level if missing */ /* selectableLevels: ["Ground floor", "Roof"], */ // Uncomment to choose the list of displayed levels, no select component if empty array */ /* camera: "Exterior view", */ // Uncomment to select a camera, default camera if missing */ /* selectableCameras: ["Exterior view", "Kitchen"], */ // Uncomment to choose the list of displayed cameras, no camera if missing */ activateCameraSwitchKey: true // Switch between top view / virtual visit with space bar if not false or missing */ }); </script>
</body> </html>
