Print at Jul 22, 2019 7:33:57 AM
Posted by bdfd at Sep 25, 2018 7:08:24 AM
confused   Re: Rename furniture
@bdfd
Why does the tool include objects outside buildings ?
Garden, trees, sidewalks,...
Update : it was only on exterior Walls (gutters, windows, doors,...).
The plug-in adds to the name of a piece of furniture only the name of a room in which the center of the furniture is located and one of its corners with a margin of 1cm.
This therefore depends on the position of the furniture in relation to a room, regardless of its type of environment (indoor or outdoor).
Ok for these explanations. smile
But I didn't understand for these... confused
I used plugin v1.4
Case 1
The room has a name : 'Master bathroom'
But the window has no name and NO named group ???
=> all furniture below in the list are in same caseā€¦
Case 2
The room has a name : 'Bedroom 2'
But the window has no name and without named group ???
Case 3
The next room, nearest of previous anomaly has a name : 'Bedroom 3'
It equipped of the same window.
The window has a name like the room ! wink
Can you explain us which is different ?
Regards,
bdfd.
confused
only 6.2 and nothing else - W10 64b
Asus TUF Z390 , Intel Core i9-9900K (3.6 GHz) , Chipset Z390 Exp, RAM 32 Go DDR4 3000 Mhz, SSD M.2 512 Go + HDD 3 To,
NVIDIA GeForce RTX 2080 8Go
