Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: can't print cant save a Sweet Home 3D file » » » » Post: Re: can't print cant save a Sweet Home 3D file |
Print at Feb 7, 2012 9:34:35 AM |
| Posted by Puybaret at Oct 24, 2007 11:47:00 PM |
Re: can't print cant save a Sweet Home 3D file Sorry, I should have asked you if you downloaded Sweet Home 3D with Java Web Start, but you guessed my mind. ;-) Could you tell me the size of the saved file (select it and type Cmd + I shortcut) ? I looks like that the homes you created are incorrectly handled. It's the first time a user reports this kind of issue, but let's try to fix it. Please launch the Console application (you'll find this application in Applications / Utilities folder), then run Sweet Home 3D, draw a few objects in it, and save the home. As you got an error, there should be something in Console window called a stack trace which looks like this : ------------ Exception in thread "AWT-EventQueue-0" java.lang.RuntimeException: java.lang.reflect.InvocationTargetException at com.eteks.sweethome3d.swing.ControllerAction.actionPerformed(ControllerAction.java:73) at com.eteks.sweethome3d.swing.ResourceAction$AbstractDecoratedAction.actionPerformed(ResourceAction.java:159) at [...] Caused by: java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:585) at com.eteks.sweethome3d.swing.ControllerAction.actionPerformed(ControllerAction.java:69) ... 39 more Caused by: java.lang.RuntimeException: Error at com.eteks.sweethome3d.io.HomeFileRecorder.writeHome(HomeFileRecorder.java:61) at com.eteks.sweethome3d.swing.HomeController.save(HomeController.java:1059) at com.eteks.sweethome3d.swing.HomeController.saveAs(HomeController.java:1041) at com.eteks.sweethome3d.swing.HomeController.save(HomeController.java:1026) ... 44 more ------------ Could you forward that error in the forum, please. It will help me a lot to find where the problem comes from. Thank you ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D developer |
Current timezone is GMT Feb 7, 2012 9:34:35 AM |
