Print at Jan 29, 2022, 7:41:17 AM
Posted by svarogrud at Sep 3, 2016, 9:01:45 PM
Re: Sweet Home 3D 5.3
Can I get 5.3 for Ubuntu 16.04, as 5.2 does not work:
Sep 3, 2016 10:47:15 PM java.util.prefs.FileSystemPreferences$2 run
INFO: Created user preferences directory.
Java 3D: implicit antialiasing enabled
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007fb023517823, pid=17739, tid=140394698073856
# JRE version: 6.0_45-b06
# Java VM: Java HotSpot(TM) 64-Bit Server VM (20.45-b01 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C [nouveau_dri.so+0x256823] __driDriverGetExtensions_virtio_gpu+0x1bad73
# An error report file with more information is saved as:
# /home/orudyshyn/bin/SweetHome3D-5.2/hs_err_pid17739.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Aborted (core dumped)
