Print at Jul 15, 2020, 12:29:02 AM
Posted by Puybaret at Aug 27, 2015, 3:22:24 PM
Re: Other rendering quality levels
If you want, you can change the values in the source code, and run the program with Eclipse. All the photo rendering properties are used in PhotoRenderer class (search calls to getRenderingParameterValue method).
You could also create a plug-in that would set the rendering properties with calls to System.setProperty method.
