Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 4.0 » » » » Post: Re: Sweet Home 3D 4.0 |
Print at Mar 7, 2021, 6:13:33 AM |
Posted by Puybaret at Mar 21, 2013, 10:52:48 AM |
Re: Sweet Home 3D 4.0 m@, thanks for reporting this issue. I could reproduce it this way: import a zip file containing a 3DS file, save your SH3D file, close your home. Each time you reopen it, the order of materials may change and so, the index of the material color you set may concern a different material. But there's an easy workaround: import the 3DS file and not the ZIP file it contains. This implies a different process in Sweet Home 3D because the 3D model will be internally saved as an OBJ file which doesn't produce this kind of "material reordering" (it's probably the reason why this bug was detected lately). Argh, I was about to release the version 4.0 and if I fix this bug, I will have to rebuild all the installers! ![]() Nevertheless, I'll see if it's easy to fix. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D developer |
Current timezone is GMT Mar 7, 2021, 6:13:33 AM |
