Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 4.0 » » » » Post: Re: Sweet Home 3D 4.0 |
Print at Jan 17, 2021, 7:06:24 PM |
Posted by Puybaret at Feb 22, 2013, 10:30:56 AM |
Re: Sweet Home 3D 4.0 Gaytan, you shouldn't worry too much about uninstalling / installing Java. The final release should come soon and it will be delivered with its own JRE. in Linux when you select an item it becomes blue and does NOT show the 'corner functions'; in OSX when selecting an item is becomes yellow and DOES show the 'corner functions'... Selection colors depends on the one you set in your system, and not on my personal choice or taste. ![]() The corner "indicators" (as I called them in the help) are visible when you select one object. Maybe you selected more than one object during your tests under Linux. Could you check again, because I don't have any issue on my side? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D developer |
Current timezone is GMT Jan 17, 2021, 7:06:24 PM |
